Survey123 print survey outputFileName value is invalid
161
03-04-2021 04:10 AM
StuartMoore
Occasional Contributor II
so i'm trying to use python to automate the generate of survey123 reports and i've finally got it to work with a generic output name but when i try and use the fields to create a smarter file name i get this error:
{"error":{"message":"outputFileName value is invalid: \"SUR_${field}_${completion_date | format:\"MMDDYYYY\"}\"","code":"003","details":[]},"success":false}
the output file name i am trying to use is this
'SUR_${field}_${completion_date | format:"MMDDYYYY"}'
now i know there is nothing wrong with the filename because if i try to create a report manually on the survey123 website using it the report runs fine and the file has the expected filename
it does work if i remove the format part but i need it in that format unfortunately
any ideas?
thanks
Stu
AllisonHollier
I'm curious to see what the answers are to this.  I just gathered the date on one line in my survey, then created a calcalute format date underneath and that's what I pull for my forms.  But that's probably the hard way.  😞
StuartMoore
still not managed to get this working
