Survey123 pre-filled link
286
5
02-26-2021 01:51 PM
jpcarp
Is it possible to generate a pre-filled link from Survey123 that can be used to populate certain fields, i.e., similar to how Google Forms does it (https://support.google.com/a/users/answer/9308781?hl=en)?
Webhooks may be a more sophisticated approach to what I want to do, but that will take me even longer to figure out, so I'm hoping to at least start with this. Thank you.
jcarlson
MVP Regular Contributor
Hard to say why it's not working for you. For browser access, just use the Survey123 web URL link and modify it the same way.
https://survey123.arcgis.com/share/<your-survey-id>?param1=value1&param2=value2
- Josh Carlson
Kendall County GIS
jcarlson
It is possible!
See @IsmaelChivite 's blog post about it here.
To briefly quote one section:
A call to Survey123 through its URL Scheme looks something like this:
arcgis-survey123://?itemID=89bc8c7844e548e09baa3aad4695e78b&field:AssetID=FF34001&field:Status=Good&center=43.567,-117.380
- Josh Carlson
Kendall County GIS
jpcarp
Thanks! Unfortunately that is not working for me. I need to allow users to fill out the form in their browser, not the app. Instructions seemed pretty straightforward but none of the fields I specified contain values. It's a 3 page survey, could that be causing the issue?
Jim-Moore
Hi @jpcarp further to @jcarlson's suggestions, here are some resources on Survey123 web app parameters:
Best, Jim
jcarlson
- Josh Carlson
Kendall County GIS
jpcarp
I was not beginning the list of parameters with a '?'
Thanks for the help everyone!
