Survey123 Populate a previous answer later in survey form
909
10-28-2020 06:30 PM
CarrieAdair
We have a License to Enter (LTE) form I would like to recreate in Survey123. On our paper form, the person has to write in their name twice, once at the beginning and then at the end. Is there a way to take what they fill in at the beginning of the form in a Singleline Text and have it populate a Singleline Text later at the bottom of the survey? The survey form needs to read like our LTE, so the landowner understands what they are signing. It seems redundant to have it in both places when I plan on uploading a template of our form and have the feature report populate in the spaces I need it to for a copy for them.
Tags (1)
CPoynter
Occasional Contributor III
Could this be a calculation where the response to Q1 is calculated as the response for Q2?
CarrieAdair
Thanks, that was helpful. I used concat(${full_name},'  ',${last_name}, ', Owner') in the calculation field of Q2 in the XLSForm that take whatever was put in Q1 & put it into Q2.
