Survey123: 'Please confirm your email address'
1323
05-16-2018 01:01 PM
ClaireMcGinn1
New Contributor II
I am creating an anonymous Survey (web form) in Survey123 Connect for a customer and would like the ability to confirm they have typed in their emails correctly. Is there a function for this?
For example:
Q1 Applicant Email:
Q2 Confirm Email:
The email type is a great new addition but only works if you are signed in unfortunately. I require a formula or instance that I can use to verify the email address typed in the first question.
Claire
JamesTedrick
Esri Esteemed Contributor
Hi Claire,
This can be done when authoring a form using Survey123 Connect.  You would need to have a check in the constraint column, checking to make sure the two questions match; assuming questions named email1 and email2, it would look like:
${email2} = ${email1}
See Formulas—Survey123 for ArcGIS | ArcGIS for more information.
ClaireMcGinn1
New Contributor II
Thanks James, I was over thinking it that's why I couldn't get it. I will know for next time; Survey123 is easy and straight forward.
Thank you!
