Survey123 Pictures
530
07-30-2019 11:33 AM
by Anonymous User
Not applicable
Hello,
I have made a web mapping application that contains a map layer of the data submitted  to one of my Survey123 Surveys. I would like for the pop-up associated with each point in my web mapping application to include the picture submitted in the survey respective to each point as opposed to just a link to the image. How can I achieve this?
Thank you for your help!
Mary
Tags (1)
by Anonymous User
Not applicable
Hi Mary,
You can accomplish this with Arcade expressions. See the following blog for instructions: https://community.esri.com/community/gis/web-gis/arcgisonline/blog/2019/03/22/show-attachments-in-po...
by Anonymous User
Not applicable
I am unable to use this method because I am not working with pictures from a file that can be uploaded. Instead, I am working with pictures that people submit through my Survey123 Survey.
Is there a way to Calculate the attachment ID of these pictures?
Thanks!
-Mary
JamesTedrick
Esri Esteemed Contributor
Hi Mary,
The steps in the blog post should work for data collected by Survey123; start at the step after uploading.
