I am looking for a easier solution for...if someone inserts an image (takes a photo or inserts) in a image question, that within the data table, a "image_attached" fills a cell in the data form.
Basically the people reviewing the exported excel table want to know if there is an image attached to a survey (within the table itself).
I could add a check box or yes/no if image is attached question for the surveyor but was hoping to have this hidden and viewable in the exportable table.
Hi Cody,
You could have a calculate question that checks to see if the image question is filled out:
if(string-length(${imgquestion}) > 0, 'yes', 'no')
Note that there is one case where this won't work - if using the web form and taking an image with the device's camera.
