Survey123 not generating a Feature Report
525
06-18-2020 12:12 PM
CarbonCounty_Utah
I will have field workers submitting surveys that were published on top of an existing feature class and related tables that are registered in our SDE. We were hoping to create Feature Reports from the submitted surveys on custom forms. However, the Feature Report tool in Survey123 website does not recognize records as being selected. (See picture.) In addition, it will not generate a report when I select all records. (It doesn't produce any errors. Nothing happens.) Does this tool work with registered data? If it does, how do I correct this problem?
IsmaelChivite
Esri Notable Contributor
Hi. Is your ArcGIS Server feature service behind the firewall? The Feature Report service must be able to query your ArcGIS Server.
