Survey123 multiple choice grid question label overflow
425
06-20-2018 08:52 AM
New Contributor III
The questions in the multiple choice grid on the survey123 form overflow (please see attached screenshot). Is it possible to remove the margin on top and move the text to the center? Can we format in the xlsform with HTML? Thank you!
Tags (1)
Reply
Esri Frequent Contributor
Hi Shirley,
What device, OS and browser version are you using? Have you tried to clear the cache and refresh browser?
Also have you tried viewing the single choice grid in latest 3.0 update of the Survey123 web app, which was released just a few weeks ago. When I create a single choice grid question with very long questions and choices, it displays them correctly without overlaps:
If you published your survey before the 3.0 update, you may need to enable the version setting to always use the latest web app to get any recent fixes to this question type. You can find the version settings under the Settings tab:
Regards,
Phil.
