I have updated Survey123 on both my iPhones (iphone 8 and iphone 6). When I attempt to download a survey that is linked to existing feature containing over 2500 features, Survey123 on both iPhones just crashed. However, I have an android that has the version before the latest update, that survey works on this android phone. I do not know if this is phone related but I do not dare to reinstall the latest version on this android in case it is the release that is the problem. Both my iPhones are installed with the latest release.
Is there any other known issues with the latest release and iPhone?
Please advice?
Thank you
Siew Wei
Hi Sterling,
No, the where clause query can only be created/modified via Connect, and it will then apply to the Inbox when the refresh button is selected. The current search box in the Inbox will only search the records that have already been queried and returned from the feature service and are already downloaded in the device Inbox.
Phil.
Thanks philip,
Is there any updates regarding the number of features in an inbox ?
Regards
Hi. Thanks for your patience. This has been addressed in https://community.esri.com/groups/survey123/blog/2019/12/05/walt-disney-release-37
