Survey123 - Is there a way to disable the recording of a 0,0 geolocation/geopoint?
706
7
03-05-2025 12:04 PM
StevenSGIS
According to this FAQ...
"Why are some of my survey results appearing off the west coast of Africa?
If your survey does not display a map question, a location is still given to every survey. If a device does not report its location, the default location stored is 0,0, which is located off the west coast of Africa. If you do include a map question in your survey, you can define a default that is more suitable for your survey."
Is there a way to disable this?
I feel it's also important to mention that I am having people record geopoints in other areas of the survey (through repeats), but the first page doesn't have a geopoint question and is still recording (0,0)
abureaux
MVP Frequent Contributor
No. Esri products are location based, even if you don't need location. As a result, you will always get a location.
StevenSGIS
I see.
Now my question is, how have people dealt with the (0,0) geopoint "feature?"
Would love to hear how other people have managed - especially when creating a webmap from the data collected.
MobiusSnake
MVP Regular Contributor
It sounds like you have a schema that look like this with repeats:
I usually define my schema in a File GDB first, publish that File GDB as a hosted feature service (with multiple layers & tables within it), then use Survey123 Connect to publish my form so it attaches to the existing service.  This is done using the Settings worksheet of the XLSX, using submission_url and form_id.
If you take this approach, you can create this schema instead:
Your top-level data will post to the table, and you won't get any points stored, but the geopoints within your repeats will behave normally.
DougBrowning
MVP Esteemed Contributor
Will you lose a lot of the 123 website stuff if you do this though?  Plus so many things get limited with tables in Esri land.
MobiusSnake
Good question, I rarely use the S123 website, for analytics/reporting I typically use dashboards and Python toolboxes + openpyxl to create custom XLSX reports.
StevenSGIS
I'll have to look into this as a potential solution.
Thank you.
MobiusSnake
I believe it will require an ArcGIS Pro Standard license since it involves setting up relationship classes, I don't think there's a straightforward way to do that using a Basic license.
An alternative solution you might want to consider would be to generate a polygon from all of the repeat points after the form has been submitted.  For that, you want to do something like this:
  • Keep the "parent" dataset as a layer, but create it so it has a polygon geometry type.
  • Do not submit a polygon in your form, don't have a polygon question in your form.  When your form is submitted, this should result in a null geometry.
  • Use an ArcGIS Online Notebook to run some Python code that compiles all of the repeat points, gets their min/max coordinates, creates a rectangle, and applies that rectangle to your parent feature's geometry, making it no longer null.  Put the notebook on a schedule to run every hour or so.
I've taken this approach using Survey123 forms in the past so that clicking on the parent feature in a dashboard list will zoom to the extent of all child points.
