Survey123 instance_name to show from select_one value?
2453
7
02-16-2020 07:34 PM
Pauline_Low_Pui_Ling
Hi there,
Would like to know if there is a way/work around to show the instance_name from a select_one value?
survey tab
settings tab
As seen from the mobile app, I could not see the values for estate_id and estate_name.
Hope someone can help me understand and let me know the workaround so that the instance_name will capture the estate_id and estate_name?
Pauline
Alber_Verster
Hi Pauline,
I managed to get the 2 values to concatenate and they are now showing fine.
I noted that you had a space in your concat function on the settings tab, removing this seems to have solved the issue. Also recieved an error about missing labels for the 2 estate name fields, which I added.
Hope this helps!
Albert
Jim-Moore
Hi Pauline
From your screenshots I can't see a reason why the instance_name is blank. Could you please provide your XLS and CSV files so I can attempt to troubleshoot?
Is the pulldata() function working correctly in the survey form?
Thank you,
Jim
Hi Jim,
I can see the estate_id now but not the estate_name.. suspect it could be due to the select_one type. Anyhow, here are the files:
estate_list.csv
survey.xls
Pauline
Jim-Moore
Hi Pauline
Thanks for the files. The link you've provided for 'estate_list.csv' opens an XLSX file. Just to confirm, is the estate_list.csv in your survey's media folder a CSV file? If you open it in a text editor it should look like this:
Using a CSV file as per above, I get the correct instance name in Outbox, Sent, etc.
Also I notice the labels for your 'estate' choice list are the same as the estate names in the CSV. In this case, instead of using pulldata() you could use the jr:choice-name() function to return the label for the choice. So the calculation would look something like: jr:choice-name(${estate_id}, '${estate_id}')
This function is documented here Formulas—Survey123 for ArcGIS | Documentation and here Cascading and external selects—Survey123 for ArcGIS | Documentation.
Best,
Jim
Hi Jim,
You are right. I need to save it as a csv file. Thanks for the guide. Will look into it possibly using jr:choice-name().
Regards,
Pauline
Alber_Verster
Hi Pauline,
Hope this helps!
Albert
Hi Albert,
Yup deleting the space in between the concat and '(' helps! Thanks for helping out.
Regards,
Pauline
Alber_Verster
Hi Pauline,
Glad that helped. Could you please mark the comments as helpful?
Thanks again.
