Survey123 Inbox personnalisation
1059
03-26-2021 08:35 AM
NicolasKleinEF
Hello,
Is it possible to customize the fields displayed in the 123Survey inbox?
Indeed, the display is not very ergonomic by default.
Thank you.
SteveOwens
ChelseaTabor1
In the settings tab of your form you'll see a column called 'instance_name'.  This is where you can customize the inbox appearance.  Here's a couple examples:
This one is using the surveyor's name as the instance name.
This one combines the responses from 3 separate fields.
I hope this helps!
