Survey123 in Enterprise 10.6.1
3307
11
01-09-2020 07:43 AM
AprilChipman
I'm trying to upgrade to Enterprise 10.6.1 and Portal. But the Survey123 app button isn't available in the launcher on the Portal homepage. Is there something I need to do to get it added?
Shwu-jingJeng
Hi April,
To add Survey123 in app launcher on portal website, it does require extra steps to add item first with your enterprise/portal url.
Here is the step by step to add item first and then add app into app launcher:
  1. Add an app to the Portal. My Content → Add Item → An Application → Type (Application) → Title (Survey123) → Tags (whatever you like) → Add Item.
  2. This will open the Portal App item once it’s created. Go to Settings tab → Scroll down to ‘Application’ → Data Source URL (https://survey123.arcgis.com/?portalUrl=https://machine1.esri.com/portal). Here please use your own Portal URL. Click Save.
  3. Now the ‘Survey123’ app will appear app a registered app when you try to Add App to the App Launcher.
  4. Select it from the dropdown, change the label, then either enter an abbreviation or upload a 48 x 48 icon.
  5. It should now appear in the App Launcher
Ypu can reference these online docs for a general steps to add apps on the Portal site here:
Add Items
Manage apps in the app launcher
AprilChipman
Yes! That's got it! Thank you!!
