Survey123: I can't get my External Select choices to populate.
2585
05-23-2016 10:53 AM
RossScott
I cannot get my external selects to populate when I click on the value. In my attached example, I have a list of a couple thousand frequencies where the user could filter the list using the first 3 digits (FequencyNumber field).  However, I can see the column heading and I am not getting an error in my application, but I when I click on the FrequencyNumber, the Frequency values do not populate.
RickeyFight
MVP Regular Contributor
This would be better if it was moved to Survey123 for ArcGIS
