Survey123, how do you find out what error codes mean? My survey is "Unable to preview survey". I don't have a clue what the details are telling me in order to correct it.
2776
07-07-2020 01:14 PM
VaLoyBriscoe
URIError: URI malformed at decodeURIComponent () at _setSurveyRow (/home/ec2-user/libs/survey123-formConverter/dist/modules/json2xls.js:1:11234) at r.questions.forEach (/home/ec2-user/libs/survey123-formConverter/dist/modules/json2xls.js:1:3547) at Array.forEach () at Promise.resolve.then.then.then.then.e (/home/ec2-user/libs/survey123-formConverter/dist/modules/json2xls.js:1:3082) at tryCatcher (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/util.js:16:23) at Promise._settlePromiseFromHandler (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/promise.js:547:31) at Promise._settlePromise (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/promise.js:604:18) at Promise._settlePromise0 (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/promise.js:649:10) at Promise._settlePromises (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/promise.js:729:18) at _drainQueueStep (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/async.js:93:12) at _drainQueue (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/async.js:86:9) at Async._drainQueues (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/async.js:102:5) at Immediate.Async.drainQueues [as _onImmediate] (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/async.js:15:14) at runCallback (timers.js:763:18) at tryOnImmediate (timers.js:734:5)
Tags (3)
DanielWalsh
I had the same issue and was able to get around it by removing the % character in my questions, specifically the hint. Not sure why but that did the trick for me.Hope it helps!
by Anonymous User
Not applicable
Can confirm this works.
Just went through 31 "%"'s on my survey and changed them to "percent" and low and behold, that fixed it. Thanks for the heads up.
ESRI needs to check their javascript, this is a big issue.
MoonLe
Today, I face the same issue, it keeps showing a string of error which I tried to create a copy, change time, but I still fail :(. May you guys help!
SierenErnst
I am also having this problem.
JamesTedrick
Esri Esteemed Contributor
Hi @MoonLe , @SierenErnst ,
Addressing these issues is best addressed by opening a support ticket with Esri support.
