Survey123 - Having a issue when creating rules on a survey in the web app
307
10-23-2018 05:47 AM
AnthonyCorcoran1
Once created and saved, when you reopen the survey the set rules have disappeared. This happens whether the rules are within or separate from a grouped question.
Philip-Wilson
Esri Frequent Contributor
Hi Anthony,
Are you still experiencing this issue? I see this post has been marked as assumed answered, but there are no further comments?
Phil.
AnthonyCorcoran1
Philip,
I have been informed that this is a know fault within Survey123 web interface builder.
GayleNeufeld
I'm getting this same problem, but it's sporatic.  I also have another rule set for a "no" answer to go to the end of the survey, but it in fact goes to a different question.  This is a serious problem - we can't use the survey if we can't trust the rules.
