Survey123 GUID prefix
354
10-02-2018 08:13 AM
EricS
I was wondering if I could put a prefix before the GUID.  Survey connect has no problem with the calculation formula "GIS_" +uuid() but when sending a survey I get the error code 10500 Database error.  Is there proper syntax for this request?
JamesTedrick
Esri Esteemed Contributor
Hi Eric,
What type of field are you attempting write to?  It should be possible via a text question populating a string field sufficiently long enough to hold it (default size of 255 characters is fine).
