Survey123 Form to IKE Office
775
03-21-2022 12:20 PM
JuanDuran
Hello, I have created a Survey123 Form to work with the SPIKE device and now I need to know if it is possible to get that data into IKE Office. Also I need to know if the SPIKE photo I am taking is usable in IKE Office to do some measurements.
Thank You.
Tags (3)
by Anonymous User
Not applicable
Hi @JuanDuran,
Can you explain the workflow a little more?
If you are using the spike appearance on an image question in Survey123, the image itself will be treated like other image and file attachments in ArcGIS. The image itself will be attached to the feature and associated to the question. If you want to extract the measurements from the image, you can use the pulldata() function to achieve this.
Please refer to following blog post and online documentation:
https://community.esri.com/t5/arcgis-survey123-blog/using-spike-with-survey123-for-arcgis/ba-p/89352...
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformsappearance.htm#ESRI_SECTION1_BA93...
As for getting the data from Survey123 to IKE Office, you would need to do this as post processing data workflows, Survey123 or ArcGIS Online/Enterprise do not have this capability.
Regards,
Phil.
by Anonymous User
Not applicable
Hi @JuanDuran,
Regards,
Phil.
JuanDuran
Thank you for your response. Now I know that I can export my Feature layer (the one that is the result of my Survey123 Form) as CSV and import that into IKE Office (just in the PRO license). Also I know now that the SPIKE Image can be used to do some measurements in the SPIKE app. In case someone need this info.
