Survey123 Form Stucks On "Getting Service Information" According To Repeat Questions
794
05-13-2020 09:11 AM
DidemBıçkıcı1
I have a problem on sending the survey from. The survey gets stuck when trying to send with the spinning wheel and "Getting Service information" then the name of the 2nd of 2 repeat groups.
I've taken a look to all the other questions on this issue. I've created a whole new survey form, updated and republished the survey, but the problem remains.. I can't get any surveys to upload.
There are two repeat groups in the survey form, I've tried with version that doesn't include repeats and it works fine. But when I add the repeat part according to original version of the survey, the wheel stucks on "Getting Service Information" and refers to the 2nd repeat group.
How can I fix this problem, I would be grateful if you can help.
Regards,
Didem
DougBrowning
MVP Esteemed Contributor
This could be the old bug on adding to a repeat only.  You need to add a dummy field outside the repeat at the same time.  Then you can delete the dummy later.  I can't find the post but this had been a bug for a long time.
Hope that helps
DidemBıçkıcı1
Hi! Thanks for your help, apparently solved my problem!
Regards
Didem
