Survey123 Feature Report Unreadable when photo is added to template
453
11-19-2019 01:27 PM
NatalieAyala
I am using Integromat to generate Feature Reports and save them to the OneDrive. When I try to add a photo attachment to the feature report via Integromat or directly through the Survey123 website, the word document is unreadable.
When I try to open the file, I receive the error messages below and then Microsoft Word allows me to recover the file as a new document and all of the data and photo attachment appear perfectly fine. I can't figure out what the issue is here.
Error Message
Unreadable Message
I believe the Integromat workflow is set up correctly. The issue occurs even when I generate a report directly from the Survey123 website so I think that rules out an Integromat malfunction. I'm using the following code in my template: ${Stations_image|size:0:0:0:125}. When I remove the image from the template the reports are generated without issue. Its only the addition of the attachment that introduces the problem.
Any tips would be much appreciated.
Thanks!
Jim-Moore
Hi Natalie Ayala
Thanks for providing your report template. Could you please try testing a report output using the built-in sample template? Click the "Create sample template" button in the Manage Templates dialog.
Cheers,
Jim
