Survey123 | Feature Report | Maybe Bug | When I remove the if statement I get a tag ${/} is unopen
493
06-02-2022 10:53 AM
MichelleWilliamsERM
I want to remove the If statement, which is outside my repeat. When I do I get the error below. Please advise!
${if (Contractor | getValue:"count")>0}
Contractor on Site ${#Contractor}
Contractor Name: ${ContractorName}
Contractor Supervisor/Representative: ${ContractorSupervisor}
Number of Contractor Personnel Onsite: ${NumberofContractorPersonnel}
Hours Onsite per day: ${ContractorHoursonSite}
Permits Completed ${#PermitSystemRepeat}
Type of Permit ${PermitSystem}
Description of other permits ${PermitSystemOther}
${#PermitSystemPhotoRepeat}
${#PermitSystemPhoto | size:300:0:0:300}
Complete JHA/JSA for each task: ${#JHA_JSACompletePhotoLog}
${#JHA_JSACompletePhoto | size:300:0:0:300}
Katie_Clark
MVP Regular Contributor
May seem obvious, but are you removing both of these lines when you delete the if-statement? The ${/} below the if-statement doesn't appear to be paired with anything.
Best,
Katie
“The goal is not simply to ‘work hard, play hard.’ The goal is to make our work and our play indistinguishable.”
- Simon Sinek
Katie_Clark
Best,
Katie
- Simon Sinek
MichelleWilliamsERM
Thank you, thank you, thank you!
I'd been looking at this all morning, and it didn't break until I removed the if statement, so I thought that was the problem. I need some coffee!
