Survey123 | Feature Report | large font bullets inside repeat
1514
6
08-06-2020 03:44 PM
MichelleWilliams1
Good day to you all,
I have a survey with a repeat, and when I print
${#Inspection}
${OperationalConditions2| appearance:"bullets"}
${/Inspection}
The bullets are always a consistent large size, and I can't seem to fix them.
I've tried different variations of HTML with no success
${#Inspection}
<p style="font-size:8px;">
</p>
${/Inspection}
JamesTedrick
Esri Esteemed Contributor
Hi Michelle,
The report template does not use HTML to specify the styling, but Word settings. I would highlight the entire section with the repeat and ensure the font sizes and styles have been set appropriately.
MichelleWilliams1
Thank you, James, normally the Word font would work, but inside a repeat, I can't get the font to change size.
The workaround is to go into the finished feature report and change it there, but I don't want to do this for every report.
Please Help!!!
JamesTedrick
Hi Michelle,
Could you file a support ticket with Esri Technical support?  If they can reproduce this, it appears to be an issue that needs to be addressed.
MichelleWilliams1
.Thank you!
Case number: 02616587
MichelleWilliams1
BUG-000133217
PeterMacKenzie2
any update on this? It seems to still be a bug in 3.18.123.
