The Integromat integraion is really great, and has enormous potential.
The issue that I am having is that I am getting an error when I run my scenario, I am getting an error with the "Create Feature Report" module. The error says "Runtime Error: Missing Reqired Parameters: "featureLayerUrl""
When I check the settings for the module, everything looks as it should based on all the documentation that I have found. Furthermore, the Feature Layer box is greyed out, such that I can't change it. If I needed to change the featureLayerUrl, I can't because of this.
Any ideas of where I am going wrong? I've included screen caps of the error and my module settings.
Hi Mark,
Thanks for reporting this issue. We had now re-enabled the FeatureLayerURL. It should work now.
Hi Mark,
Excellent, thanks for letting me know! It is working now.
