Survey123 exporting name rather than label
10953
34
12-06-2017 03:39 PM
GarretDubois
I have a field in my survey that is showing the information in the name column rather than the label column when the data is viewed in survey123 for ArcGIS, or exported from survey123 to AGOL.
There are other rows that are similar in the survey but are showing up correctly in the data tables when viewed in survey123 for ArcGIS.
Question 1. Does anyone know why this is happening?
Question 2. Is there a way to fix this problem?
JohnathanHasthorpe
Hi Loretta and Shana
It looks like you are both being affected by a known limitation.
When choice_filter used, the name text is saved as the data value, instead of the label text.
Shana - can you confirm that you are using choice filters? Also, have you thought of using a pulldata() instead?
You could just create a .csv lookup between name and label - this would be easier to manage.
John
ShanaGail1
I'm not using a choice filter, it's just a select_one question with a handful of values in the list.  The other select_one questions work just fine.  I'm adding another 40 values to the list however.  I'll look into pulldata, but I'd like to get at the root cause of why the select_one isn't working.
Shana
JohnathanHasthorpe
Hi Shana
Could you share your survey with we and I'll take a look? If you are not using choice filters - this is not expected behaviour.
John
ShanaGail1
JohnathanHasthorpe
That is the one - thanks
oscaralfredogonzleon
HI guys, i have the same problem, can you help me? thanks alot
LeaHarper3
Hi Jonathan - is there going to be a fix for this? I have the very same issue as Shana. I'm not using a choice_filter, just select_one but the data is only displaying the ID that is in the name field, not the label.
JohnathanHasthorpe
Hi Lea
Can you share your survey? The bug we have open involves the choice filter.
John
ShanaGail1
Hi John,
I decided to try and replicate what Lea saw because adding new select_one choices have been a headache for a variety of reasons.  Here's what I did:
1) Added a new choice to repeat questions and republished
2) Submitted a Survey using these new choices
Results: The names showed in the related tables instead of the labels.
Is this expected behavior?
Shana
ShanaGail1
I since found that the behavior was not limited to related tables.  I added new choices to my other select_one lists not in repeats, republished, and had the same results.  Names, not labels displayed in the fields.
