Survey123 Export Report Photos not showing
5008
23
03-27-2019 12:49 PM
SeanLavallee__MES_
New Contributor II
 I am working on reporting functionality using survey123 custom report templates. It works great with the exception to the photos. But, only surveys entered in survey123 will add photos to the report. Anything edited in collector, updated feature service, or old surveys will not print up. I was reading about a issue with old surveys and the metadata for survey123 will not read the old metadata when exporting to reports. I noticed that if you print your data from survey123 it will print all the photos regardless of time frame of when surveys were submitted or if they were updated in collector or ArcMap. If they can read and print photos to a document, why can't they export the photos from the table to the form? Will this functionality be added soon?
It would be great to have this functionality seamless since ArcPro reporting function does not allow photos and ArcMap Desktop is being phased out and hard to work with.
Printed from Survey123 - This report exported not have photos, but print will.
Same exported Report
DidierAlvarado
HI, James,
just want to know, if this is already sorted and working? we used to use, the export reports from ArcGIS Online accounts and we just migrate to portal last week.  we really need this as we have been using it last 2 years from the ONLINE accounts
NaufalIhsan1
New Contributor II
Hi, it's been a year since the last reply. Is there any follow up to this issue? Because I have the same problem.
VincentRobinson
New Contributor III
Me too
JamesTedrick
Esri Esteemed Contributor
Hello,
The reason that photos do not appear with ArcGIS Enterprise is that Enterprise currently lacks a feature to be able to determine which photo is associated with a given question; this is ENH-000125371.  We will be providing documentation in the next release of Survey123 on the proper formatting for the syntax:
${#$attachment}
${$file}
${/$attachment}
TravisSmith1
New Contributor III
For some reason when using the above I am able to get one photo in the report, but not multiple. For example, I have two images that show up just fine when viewing the record within the website, but when I run the report with the fix you provided only one of those photos is output. I also tried creating a brand new test survey from the website that supported the multiline appearance for multiple image support in one image question, but am getting the same result. Any reason why both photos aren't coming through to the report?
TravisSmith1
New Contributor III
Using Portal 10.7.
NiekGoorman1
New Contributor III
Hi James,
We are running into this exact issue with ArcGIS Enterprise 10.7.1. Could you let us know what the status of this fix is? Will there be a patch coming out soon?
MCDGISAdmin
Having same issue and limitation with Enterprise using Portal.
LetíciadAgostoMiguelFonseca
New Contributor II
Hello everyone, is there a workaround about this issue? Thanks!
DidierAlvarado
HI leti
did you get any solution??
thanks
