Survey123 displaying name rather than label when using select "select_multiple" questions
773
06-18-2018 04:11 PM
New Contributor III
The table for my survey is displaying the information stored in my name field instead of my label field when I use a "select_multiple" question.  I don't have that same issue when I use a "select_one" question. Is there any way to fix this problem? I know a similar question has been asked before, but I didn't see a direct solution to this problem.
Any help will be appreciated!
Reply
Hi Carlos,
This is expected behavior; select_multiple questions send only the name of a choice to the feature service, while select_one questions send the name and the label. This is mentioned in the documentation: XLSForm essentials—Survey123 for ArcGIS | ArcGIS
Hi Carlos,
