Survey123 Desktop Connect Sign in with ArcGIS Enterprise
923
09-14-2023 11:33 PM
RaghavGupta
I am trying to sign in Survey123 Dekstop connect with ArcGIS Enterprise. However, in the environement we are not using webadaprtor instead we are using the portal url with port numbers. When I am putting that url for sign in Survey123 Connect it is not taking that url.
Can anyone Please confirm if the survey123 desktop connect needs webadaptor url to signin.
There is no error also.
Thanks
ZacharySutherby
Hello @RaghavGupta
You will need to use https://<yourPortal>:7443/arcgis as the URL the first thing that Connect does is access a Portal resource to obtain information about the organizations properties.
Additionally usually accessing the Portal through the port is not configured with a SSL certificate so you will likely also receive a SSL error. To work around this click and hold on the text "Add Connection" you will see a new option pop up. Try to enter your Portal URL https://<yourPortal>:7443/arcgis and it should error out with the SSL handshake error. You will then see an option to Ignore SSL errors, enable this option and Add the Portal again.
Thank you,
Zach
