Survey123 data in one field not visible or exportable
489
08-14-2019 07:56 PM
NealeHutcheon
I have survey with a bunch of similar style of yes/no questions together but one won't show any values in the Survey123 webpage Data tab or in anything exported (XLS,Shape,KML). The Analyze tab DOES show values in this field for all records. It is also possible to filter on those values, but still nothing appears in the field's column. Anyone experienced similar to this?
JamesTedrick
Esri Esteemed Contributor
Hi Neale,
One thing I might check is to see if there are domain values that do not match the data being stored (i.e., the domain has coded values of 'Yes' and 'No' and the values being written are 'yes' and 'no').
