Survey123, Custom Map and and new Map Viewer
468
07-02-2023 08:38 AM
bkaplan1
I found that when I added a custom map created using the new map viewer to the map widget in Survey123, the colors were lost. I saved the map in the classic view and changed the colors to use it in Survey123 and got my colors back.  Has Survey123 been updated to use the new map viewer and I'm not doing something right?
bkaplan1
After adding the colors back and saving the map in classic view, the classic map worked in Survey123.  I then saved the classic map vack in the new map viewer and the colors persisted.  However the use of hatching in the new map viewer doesn't work in Survey123. Furthermore, for performance, I created a vector tike cache to use instead of the straightup map.   I also noticed differences on how the map worked in the Survey123 mobile app vs browser and I like the map response better in the browser
