Survey123 crashes when multiple select one questions answered within a repeated group
273
04-30-2018 08:04 AM
DanielKonzek
I have 2 surveys that include multiple (up to 40) select one questions within a repeated group.  Both of these surveys are used to count species occurrence.  A user selects a species from a list (select one) and then enters the number of observances for that species.  When 5 or more species are selected and the user taps the '+' sign in order to repeat the group of species questions at a new location Survey123 crashes.  This takes place with versions 2.4 - 2.7 of Survey123 for iOS and desktop.
When a user first goes back to a previous repeated record and then taps the "+" sign the app does not crash.  This is not a feasible work around when your first repeated record contains more than 5 species.
I believe this issue is addressed in BUG-000111086.
Any suggestions for a fix?
Thank you,
Dan
Reply
JohnathanHasthorpe
Hi Dan
Can you share your survey xls and the details of the device you are using?
That way we can try to replicate the behaviour and confirm if it is a result of: BUG-000111086.
Thanks
John
Reply
DanielKonzek
Hi John,
  We are experiencing crashing on various iOS.  I am currently testing on an iPad Air with Survey123 version 2.7.
I will need to email you my xls.  What is the best email for me to send it to?
Thank you very much for your assistance,
Dan
Reply
JohnathanHasthorpe
Hi Dan
Thanks for the survey - I was able to replicate the issue and it looks to the same bug.
It is possible to stop the crash by removing the relevant statements inside the repeat. Because each one is doing a string-length calculation, this freed up some memory. Not ideal, but it will allow submission until we have a fix.
Thanks
John
Reply
DanielKonzek
Hi John,
  Thank you for the workaround.  I reformatted my survey to have a 'pages' style, put all of the species questions onto one page, and then grouped the 40 species questions into groups of 10.  This way there was only 4 relevant statements.  This seemed to work.  It is still not ideal, but will allow us to continue to use Survey123 until the bug is fixed.
Thanks again,
Dan
