Survey123 Connect
487
06-21-2018 11:53 AM
Sierra
New Contributor II
Hi!
Is there a way to dynamically rename an image taken within a survey to an entry from an existing field (in the same manner as an instance of a survey can be saved with the field(s) data entered in the survey)? For example, these are the fields on the form: project, survey date, issues(repeat group), image(repeat group nested within the issue repeat group) -- is there a way to automatically name/label images to something like these:
"ProjectA-SurveyDate-Issue1-Image1"
"ProjectA-SurveyDate-Issue1-Image2"
"ProjectA-SurveyDate-Issue2-Image1"
"ProjectA-SurveyDate-Issue2-Image2"
Thank you!
#Survey123 images
IsmaelChivite
Esri Notable Contributor
Sorry. It is not possible to calculate the name of an attachment within XLSForm.
Sierra
New Contributor II
Thank you!
