Survey123 Connect
1249
03-02-2022 01:39 PM
JoyiaWilliams
I am running through a tutorial and trying to get used to survey123 on the web and with the field app. However I can't seem to complete the survey on the field app. A message pops up saying "Data values are valid"  and won't let me complete them. Any advice?
2 Solutions
TL2
You can't submit data in Connect.  What you see is basically a confirmation that your data will submit in the field app.
MarcoPoetsch
As @TL2 mentioned, you can't submit data in Survey 123 Connect. If you want to test your field app on your desktop, you would need to install the Mobile Survey123 app:
MS Store: https://www.microsoft.com/en-nz/p/arcgis-survey123/9nblggh5wmrr?rtc=1&activetab=pivot:overviewtab
TL2
MarcoPoetsch
