Survey123 Connect - Thank You screen and counter?
2768
6
12-11-2018 12:43 PM
AllenRisley
Two questions:
1) Is there a way to implement a "Thank You" screen when programming with Survey123 connect?  After data is transferred I would like to have survey respondents jump/continue to a screen that has web links to other resources related to the survey topic.  Is there a way to do this?
2) Is there a way to display a counter so that respondents can know how many surveys have been collected?  My survey is part of a community action campaign and the client believes we will get greater participation and repeat participation if respondents can see how many times users have submitted data.  Is there a way to do this?
Thanks in advance...
Allen Risley
GIS Specialist
Cal State University San Marcos
JamesTedrick
Esri Esteemed Contributor
Hi Allen,
1) Survey123 Connect currently does support setting the Thank You screen.
2) There currently isn't a method to display a count of the number of surveys;
AllenRisley
Thanks James.
Is there a way to trigger having the data save for a survey before the final submit button is sent? That way I could include a link to an external website where respondents could receive additional information.
Allen Risley
GIS Specialist
Academic Technology Support
Instructional & Information Technology Services
California State University San Marcos
Office: Kellogg 2437
Phone: 760-750-4169
Email: arisley@csusm.edu<mailto:arisley@csusm.edu>
#ThoughtsBecomeThings
by Anonymous User
Not applicable
Allen,
You should look into the use of webhooks if you are utilizing the Mobile app for users to fill out the forms. You can have an automated email sent to the person filling out the form after the survey has been submitted.
You can also take a look at one of my questions that turned into a discussion about the use of URL links through a "note" question.
https://community.esri.com/thread/194609-not-your-standard-note-question-email-link
I'm not a hundred percent sure on how to show number of surveys submitted.
Good Luck!
SarahHartholt
Where can the Thank You screen be customized using Survey 123 Connect?
LarsArneson
@SarahHartholt Were you able to figure this out? I've seen you comment on a few other threads about it. I had to pull my survey down into Connect to add a few functions and now the "Thank you" screen is showing "If thank you screen content is specified in Survey123 Connect the content below will be ignored."
I don't believe I have specified thank you screen content in Connect. If I did without knowing it, I don't know how to find it and delete it from the file so that I can control the appearance of the thank you screen from the web.
Boyang_Wang
Wondering the same thing.  Does Survey123 Connect now support setting the Thank You screen? I cannot find where the setting is in Connect, while customizing Thank You screen in Surver123 web app does not work.
