Survey123 Connect Running Count Calculation
118
12-03-2018 06:12 AM
deleted-user-sNUdtFrn2yEY
New Contributor III
Hello -
I'm trying to write a formula that will generate a running count as each survey is entered. I used the following:
type         name                  label    calculation
calculate   runningcount     Count   count(${Not sure which type field is the best to use here})
This formula gives me the number one, but when the second survey is entered it still gives me a one
I'm trying to get the following:
SurveyID  Running Count
12345               1       1
15678               2       1 + 1
33456               3       2 + 1
67891               4       3 + 1
Thanks in advance for your help with my question.
Best regards,
Colleen Madigan Schelde
Reply
JamesTedrick
Esri Esteemed Contributor
Hi Colleen,
This can be done when you are counting repeats within one form (using the formula once(count(${FIELD})) in a question inside a repeat).  There isn't a method to count between separate survey submissions.
New Contributor III
James -
Thanks so much for the follow up. Appreciate your input.
Best regards,
Colleen
Reply
