Survey123 Connect: Ranking Question Responses From Most Desired to Least (1-3)
1706
02-15-2018 10:58 AM
ZachYinger
I am making a survey where viewers will be asked to look at 3 images. The user is then asked to rate the images from 1-3, 1 being the most liked or desired image and 3 being the least. I've looked into multiple response survey questions, but haven't been able to come across anything related to presenting ordered multiple choice responses. I believe I am making myself clear, if there are any misunderstandings I am more than happy to show my survey and a more pictorial guide to my dilemma. Thanks for your time!
JohnathanHasthorpe
Hi Zach
Please try the following:
It will only let the user submit unique values, and will provide a rank of 1-3 for each image.
John
ZachYinger
John,
Perfect! Thank you for both of your responses, they both worked out.
-Zach Yinger
MJBiazar
This functionality is now supported in both Survey123 web designer and Connect. The GeoNet blog linked below outlines the workflow to use "rank" question type to enable users to rank their responses on the form:
All the best,
MJ
