Survey123 Connect Image question and Multiline Appearance
7002
11
08-17-2020 10:24 PM
JamieLambert
Hi All,
Looking the new form in Survey123 Connect and it looks good! Just had a question about the MULTILINE appearance and the IMAGE question. On the APPEARANCES tab, the MULTILINE appearance is only shown for the TEXT question. Can this be updated for the IMAGE question? And does this apply to the Web app? I have used it in a Web form (from Survey123 Connect) embedded in a Dashboard and I can add multiple images, though when I submit the form there are no attachments. I guess I need to understand if its not working as its not fully supported in the web form yet or its another issue I am facing. Thanks.
Jamie.
Jim-Moore
Hi Josh, thanks for the additional info. It sounds like you're using an older version of Survey123 Connect (the product name also suggests this - the name changed from "Survey123 Connect for ArcGIS" to "ArcGIS Survey123 Connect" earlier this year). Could you please check which version of Connect you have installed?
Support for the multiline appearance for image questions was introduced in version 3.10; note that the current version is 3.11 (released last week). Latest downloads available here: ArcGIS Survey123 Resources | Downloads, Training, Videos & Documentation.
Best,
Jim
FRSadmin
I believe I have the latest version of Survey123 and I cannot get the multiline for images to work at all.
This wouldn`t be weirdly region locked at all would it? I am operating out of Japan.
