Hi All,
Looking the new form in Survey123 Connect and it looks good! Just had a question about the MULTILINE appearance and the IMAGE question. On the APPEARANCES tab, the MULTILINE appearance is only shown for the TEXT question. Can this be updated for the IMAGE question? And does this apply to the Web app? I have used it in a Web form (from Survey123 Connect) embedded in a Dashboard and I can add multiple images, though when I submit the form there are no attachments. I guess I need to understand if its not working as its not fully supported in the web form yet or its another issue I am facing. Thanks.
Jamie.
Hi Jamie
Thanks for flagging the issue with the template. As of 3.10 the multiline appearance is fully supported in the field app and web app, for both image and file questions. I've updated the Appearances tab in the Advanced and Standard templates accordingly.
Regarding the issue you're seeing in the dashboard - I'll leave this one to my colleague Jody Zheng Liu, above!
Best,
Jim
Hi Jamie,
Are you using Enterprise portals or ArcGIS Online?
Jody Zheng Liu
Hi Jody,
Using ArcGIS Online. I am adding new data with the survey rather than editing existing data. The survey is built from an exiting hosted feature using Survey123 Connect. The Image question appearance is set to Multiline and method=browse.
Now knowing it's supported, I spent some more time looking at the data and trying to work out what was happening - and its working now. I had a field called 'Images' that was meant for a URL for existing data - with new data having the images actually attached. At some stage I had a less constructive moment and forgot about my original intention, and repurposed this as an Image question! When I saw the 'Images' attribute in the table just now I knew I did something wrong! Interestingly the image question (which was really a text field) was actually capturing the filenames of the images I was trying to upload and writing them to the text field (see image below). So even though it looked like I was adding images, I was not.
I added a new Image question with the same parameters and republished the form. This has resolved my issue. Thanks for your help.
Hi Jamie
Best,
Jim
Hi Jim,
Thanks for letting me know that the multiline appearance is fully supported on the web side - helped me narrow down where my issue was! The new image question functionality is great to have.
Jamie.
Hi @Jim-Moore & @JodyZhengLiu
I've again encountered this issue in version 3.17, set multiline appearance in Connect but couldn't add multiple images in the web.
Please help to resolve this problem, thank you.
Hi @JackTsai
Are you publishing a new survey from Survey123 Connect or updating an existing one? If it's the latter, you might need to add version=latest to the URL to ensure you're using the latest version of the web app.
Could you please try publishing a new survey from Connect with a multiline image question and see if it works in the web?
Please note the latest version of Survey123 Connect was released September 2024 and is version 3.21.
Best, Jim
cc: @JodyZhengLiu
In Survey123 Connect (enterprise license) the multiline / multiple photos is not shown on the screen. Though when I publish the survey and look at it on my phone, it would be helpful to see this present in Survey123 Connect as well.
Hi Josh Mccullough, could you please provide a bit more detail about what you're seeing in Survey123 Connect versus the Survey123 field app? Or are you viewing the survey in the web app (browser)? Are you using the multiline appearance with an image question?
Best,
Jim
Hi Jim -- I'm viewing this in the Survey123 Connect (Programs > ArcGIS > Survey123ConnectforArcGIS) where I'm developing the survey. I am using the multiline appearance for the image. In Survey123 Connect, after taking a photo the icon options below the image preview and jpg name are the same camera and folder with the rotations and delete icons added -- here there is no "plus" icon to take multiple. Meanwhile, on my phone app for Survey123, after taking the photo the icons below the image preview and jpg name change to include a "plus" icon by the camera and folder icons. On Survey123 Connect taking a second photo doesn't allow you to scroll back and see the first photo, but on the Survey123 phone app there's left and right arrows to go between the photos taken.
