Survey123 Connect body::esri:visible expression
1065
07-23-2024 04:38 PM
TKSHEP
How would I use an expression in body::esri:visible to show a field if it does not contain?  I tried ${device}!='Texas' and ${device}!='Arizona' and ${device}!='Nebraska' however it still does not show the filed if it is not those area's.  Any help would be greatly appreciated.
Thank you!
abureaux
MVP Frequent Contributor
Doesn't contain what, exactly? Is that a "State" dropdown menu?
Also, you may wish to try "or" instead of "and"
TKSHEP
Tried both "and" and "or", still no go.
DougBrowning
MVP Esteemed Contributor
Few things to try.
First is this a select one or select multiple?
Second are you checking the Name or Label value?  You need to check the name value from the list.
Third I have sometimes seen != getting weird if there is no spaces.  Try  ${device} != 'Texas'
Fourth if none of that works try not(${device} = 'Texas')
Hopefully one of those does it.
TKSHEP
${device} value is a text value, and I have tried all of the above, the not statement, the spaces.  Still not working, unless I am unable to do it with a text box value.
abureaux
These equations are caps sensitive.
  • If this is a "text box" that allows open input, then this likely won't work well. People misspell worsd (haha?) all the time.
  • If this is a drop down such as a select_one or select_multiple, be aware that you need to reference the name rather than the label. For example, using the below image as reference, selected(${my_question},'yes') will work, while selected(${my_question},'Yes') will not work
