Survey123 Classic unavailable?
190
11-05-2019 07:18 AM
ErickWiggs2
New Contributor III
Has Survey123 Classic been removed from the Google Play Store?
Older tablets that have it installed are able to locate it, but we are having issues finding it in Google Play for devices that do not have an installation. These are 32bit tablets.
We are currently unable to switch to the newer style of Survey123 due to the requirements of archiving/ syncing  transactions on the database.
Tags (1)
Shwu-jingJeng
Hi Erick,
We had stopped supporting Survey123 Classic and thus you won't find it on Play Store now. I'd suggest to plan an upgrade of your database and survey, instead of using Survey123 Classic. You could also open a ticket with Tech Support to help you migrating your production to a newer version of Survey123. That way, you will have full support of Survey123 when you running into issues.
