Survey123- Choices, Constraints, Groups
3506
01-18-2016 06:29 AM
StevenMichalek
Developing a sample Survey I have encountered a couple of issues.
1. Can you assign a constraint to a none required field, but only apply constraint if the field is populated?
2. Choices tab. Name Column
      A. Is there a way to overcome the 32 character limit in the name column?
     B. Name column can not contain spaces. By Design?
3. Can you minimize Groups?
IsmaelChivite
Esri Notable Contributor
Yes. Constraints will only evaluate if the user has typed an answer.
No. The strings you can use in the NAME column are restricted because we use them to create fields in the underlying database that feeds your survey Feature Service.
Unfortunately not at the moment.
IsmaelChivite
Aurelija_RutaViluckyte
Hello Ismael, what about a possibility to set a constraint only to one of the choices in the drop-down? Is that possible?
There are four possible choices, but constraint is needed to only one of those in the next question.
Thanks in advance.
-Aurelija
