Survey123 Choice values get stripped of leading zeros
7100
21
03-12-2021 08:21 AM
TonyDaSilva1
I think there is a bug with string based values for select_one text fields where if the text looks like a integer but is preceded by zeros (000123) it gets stripped and ends up in the feature class like (123).
Please fix this.
Tags (1)
Cyprus_Forest_Department
This also works with Type=textappearance=numbers, and bind::esri:fieldType=esriFieldTypeString.
This way you have the little calculator for input as well!
JoshConrad1
