Survey123: Change the label of "or other" field
4430
04-15-2016 05:47 AM
AliBarakat
Hello,
I am using in Survey123 this "select_one GroupName or other"
I want to change the label of the other field in the survey.
does anyone have an idea on how to do this?
Thank you
jordixirgo
And the "Specify other." too...!
AdrianWelsh
MVP Honored Contributor
Ali,
That's a great question. I could not find a way to do this through the form and software. If you were to move this thread to the Survey123 for ArcGIS​ place, you will get more visibility there. I am tagging Ismael Chivite​ as well.
IsmaelChivite
Esri Notable Contributor
HI!  Referencing a previous discussion which addresses this: Can I change "or_other" language in the select_multiple [list_name]?
jordixirgo
Great!
Thank you,
Jordi Xirgo
UMAT - Ajuntament de Girona
AdrianWelsh
Wow, that is quite a work around. But I suppose this works!
