I have a simple Survey123 form with a geopoint that I made using the GUI. When I click 'Set Location', I get an address lookup box within the map locator field. I am using the locator to select a geopoint in an open park setting, so the address field isn't needed.
Thanks in advance for any clues...
Hi Mike,
There currently isn't an option to remove the address search field. The address lookups count as geosearch (the non-credit consuming) as the user still has the opportunity to change the location before storing the data.
Thank you for responding to both questions!
