In survey123 the camera will not switch from selfie to rear facing on Android . i have granted permissions to the camera removed and reinstalled the app and still no joy. Anyone else have this issue?
Hi Philip
My device is reporting 3 cameras
Thanks
Hi Paul,
Thanks, that is very helpful. We are working on a fix and should have it available for the upcoming 3.11 release. Once It is available on Early Adopter Community you can test out the 3.11 RC2 builds if you want to try it earlier.
Regards,
Phil.
Hi Philip
I have the same behaviour in the Samgsung A30s, the camera doesn't switch between front and back camera. Do you have any solution for this issue?
Regards
William
Hi William,
As per my post below in this thread, the camera switcher issue on some Android devices has been fixed and will be available in the 3.11 release. You can test out the fix with the latest 3.11 RC2 builds now available on the Early Adopter Community.
Regards,
Phil.
NOTE: This email chain appears to contain email from outside Golder
I have done the same with my Galaxy S9, still won’t switch.
Ryan Gillespie
GIS Specialist
Golder Associates Inc.
7245 W Alaska Drive, Suite 200, Lakewood, Colorado, USA 80226 ◄ WE Have Moved!
T: +1 303 980-0540 | 😧 +1 720 920-4613 | C: +1 540 968-3756 | golder.com<http://www.golder.com/>
LinkedIn<https://www.linkedin.com/company/golder/> | Instagram<https://www.instagram.com/golderassociates/> | Facebook<https://facebook.com/golderassociates/> | Twitter<https://twitter.com/GolderAssociate/>
Work Safe, Home Safe
This email transmission is confidential and may contain proprietary information for the exclusive use of the intended recipient. Any use, distribution or copying of this transmission, other than by the intended recipient, is strictly prohibited. If you are not the intended recipient, please notify the sender and delete all copies. Electronic media is susceptible to unauthorized modification, deterioration, and incompatibility. Accordingly, the electronic media version of any work product may not be relied upon.
Golder and the G logo are trademarks of Golder Associates Corporation
Please consider the environment before printing this email.
Hi Philip mine is an Samsung galaxy A20e running android 10 and this issue is present across numerous similar devices in my org. I ll see if IT has a spare phone I can test with .
Dear Paul,
we encountered the same problem with a Samsung galaxy A20e in our organization. Did you happen to find a solution to the problem?
Best,
Marcus
Hi Marcus,
The problem appears to be related to the number of cameras being reported by the device, in some cases there are 4 cameras (2 front and 2 rear cameras) but in other cases there are just 3 or 2 cameras. The device treats this hardware as one camera front and back, but in some cases where 3 cameras are reported it is causing the camera switcher to try and access them individually as if they are separate cameras. We managed to test on a A20 and see the issue reported.
Can you please take a screenshot of the About screen in the Survey123 app, press and hold on the AppStudio icon in the bottom left hand corner to expose more details and then scroll down to the camera section. It should look similar to following screenshots:
I just want to check how many cameras are being reported on the device you are having issues with.
Regards,
Phil.
Dear Phil,
thank you very much for your help. Our device is also reporting 3 cameras (see screenshot). Any help with the problem is very much appreciated 😃
Hi Marcus,
Just letting you know the issue with the camera switcher on some Android devices that you reported above has been fixed and will be available in the 3.11 release. You can test out the fix with the latest 3.11 RC2 builds now available on the Early Adopter Community.
Regards,
Phil.
