Survey123: calculation based on a old value in the database
392
06-16-2020 02:43 AM
PanGIS
Hi guys,
I am trying to create a small form that make easy the collection of values and makes the calculation on its own:
(I am using Connect)
Here is the case:
on the  20/03 I have a total =  64
on the 21/03 I input New = 9
so the calculation takes the total of yesterday and add 9+64=73
(on the other way round if I need to subtract a value from the one of yesterday)
Is there a way I can get  "case  total" = 73 without checking the old value in the table and make the addition manually?
Thanks!
DougBrowning
Are you trying to pull the value from an old form?  Or is this in a repeat?  In the web map?
If you are looking across form then Arcade in a web map would be a way to go.
Hope that helps.
