Survey123 calculating geopoint defaults back to GPS
2989
11
08-07-2018 07:28 AM
AndySchmidt
New Contributor II
I am having an issue with Survey123 calculating a geopoint  which defaults back to GPS location.  I am using Collector to launch the survey and pass values to the survey including a Latitude and longitude value then calculating the geopoint using concat(string(${LATITUDE}), ' ', string(${LONGITUDE})).  It initially takes the calculated point then zooms to my current device GPS location.  I can get the location back by pressing the refresh button on the map in survey123. This worked in the past but with the recent updates in version 3.0 this is no longer working for me.  I want it to default to the calculated location so it shows the location of the asset vs the location of the device where the survey is taken at
  Defaults to device GPSAfter pressing the refresh button it changes to the calculated X,Y from above
2 Solutions
JamesTedrick
Esri Esteemed Contributor
Hi Andy,
To pass the location to be used in the map, you should use the center=<lat>,<lon> parameter instead of calculating from fields.  That being said, I do see the behavior you are describing and will file an issue to fix.
ChaimSchwartz4
In my form I have a geopoint field called "inspectionLocation" and then two fields that capture the coordinates through the calculation column:
inspectionY:	pulldata("@geopoint", ${inspectionLocation},"y")
inspectionX:	pulldata("@geopoint", ${inspectionLocation},"x")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
And then I pass that into a geopoint row in the repeat once again through the calculation column:
${inspectionY} + " " +${inspectionX}‍
Hope that helps.
JamesTedrick
Hi Andy,
ChaimSchwartz4
Hi James Tedrick, I am having the same issue, however, I am already using center = (lat, long) to pass the coordinates from collector to survey123, but now need to once again pass the same coordinates to a related table (repeat) within the survey. I tried to do so using a similar "concat" to the above, but it doesn't work (it actually seems to be working when testing in the survey123 connect app, but then doesn't work in the actual (iphone) app. Is there a fix/workaround for this?
JamesTedrick
Hi Chaim
Are you using the pulldata('@geopoint') function as part of the calculation?  This sounds similar to an issue that is being worked on.  We will be releasing a release to the early adopter community that should address this soon (3.4.119); could I ask you to test once it's available?
ChaimSchwartz4
Yes, I am using the pulldata("@geopoint", ${....},"y") function. I also saw elsewhere that there is a more general issue with coordinates not auto-captured in related tables, so perhaps this is a related issue. If this is to be addressed in a short release that is great news, and I will certainly be happy to test.
JamesTedrick
Hi Chaim,
The updated versions are now available at the Early Adopter Community.
ChaimSchwartz4
Works like a charm!! Tested on the windows version since IOS is still pending. Thank you for this this is great!!
JuulDaemen
Hi Chaim,
Looks great! And exactly like what I'm looking for.
I'm still wondering how you managed to use the x and y fields as input in the geopoint field in the XLSX?
Thanks.
ChaimSchwartz4
Hope that helps.
JuulDaemen
Thanks Chaim, it works perfectly now!
