Survey123- Calculate data in current inspection based on last inspection
664
10-16-2019 02:37 PM
DarenThompson
I would like to create a survey where my operators enter hourly tank levels along with other inspection data each hour.  I would like to calculate a field each hour that takes the current level and compares it to the last level entered the previous hour so that we can populate a field called tank level drop since last reading.  Does anyone know if this is possible in Survey123?
JeremyJohnson5
You could use the inbox functionality to add additional entries/edit a form that was previously submitted.  You could set up your questions as a repeat to work with the inbox or have multiple questions filtered out by a relevant entry.  The form would need to be built using Survey123 Connect.
