Survey123.arcgis.com & Enterprise Portal
789
05-21-2018 08:14 PM
ChrisRoberts2
Hi All
I have followed through the Tech Support article on configuring our Portal for ArcGIS 10.4 to work with survey123.com.
Unfortunately when i try to login using a configured url as suggested in the doc I get this error:
https://survey123.arcgis.com/?portalUrl=https://location.sa.gov.au/portal
When I check the appid and redirects in Portal it all seems as it should
{"appId":"survey123hub","redirectURIs":["\\http://survey123.arcgis.com\\","\\https://survey123.arcgis.com\\"]}
Not sure what else to check or do?  Any thoughts will be greatly appreciated.
Cheers
JamesTedrick
Esri Esteemed Contributor
Hi Chris,
It looks like something is a little off in the Portal's configuration.  If I attempt to go to the login page configured to open Survey123 after completion (https://location.sa.gov.au/portal/sharing/rest/oauth2/authorize?redirect_uri=https://survey123.arcgi... ), the request returns a "302 Found" response that redirects to https://location.sa.gov.au/ .  Can you check with your Portal administrator to see if there is anything in the configuration of the Portal that would cause this?
