I am trying to setup an inspection workflow using Collector and related tables (or Survey123). Not sure which to use yet. FYI, we are using ArcGIS Online for this.
Here are my requirements:
I have seen ways to pass data from a feature service to Survey123 through the custom URL, but I also need to pass data back to the main feature service from either the related table or Survey123.
Thank you in Advance!
Hi Ryan,
It is not possible to pass data back from a related table layer (repeat) in survey123 on submit to another feature service or the parent layer. You would need to do this via script or port processing, or you could try using a webhook.
Phil.
