Survey123 & Microsoft Power Automate - Extract Attachment - Suddenly Cannot get Attachments
532
05-16-2023 05:30 PM
rsun_TQB
Hi Everyone,
I am wondering if anyone using ArcGIS Enterprise 10.9.1 with Survey123 (not on-prem) are having issue with Power Automate is not able to get attachment based on fantastic tutorial here: (1) Survey123 attachmenrs in Microsoft Power Automate (esri.com)?
I did not get any token returned but got the following error: "Could not access any server machines. Please contact your system administrator."
We use local portal administration account with Survey123 (Custom Connector) since we are using Portal with S123.
Previously
Currently
Thanks a lot,
Reno
rsun_TQB
Hello everyone!
Found a workaround here!!!
Solved: Changing hosted Feature layers with Power automate... - Esri Community
It's not ideal to have credential exposed in Power Automate, but this method above allows me to use HTTP action to generate secure token using user's credential who is able to access attachments!
Then, use the token to access attachments 🙂
Cheers!
rsun_TQB
Survey123 + MS Power Automate extracting attachments only works when the user has a corporate account filling the survey for now. If I found more info, and hear and updates...I will keep you guys posted 🙂
Survey123 + Microsoft Power Automate for Public Fa... - Esri Community
rsun_TQB
Hello everyone!
Cheers!
